`95 24 Outlaw swim platform >
Old 06-11-2003 | 03:05 PM
Smitty's Avatar
Default `95 24 Outlaw swim platform
Has anybody had any luck removing the factory/stock black or grey foam covering from the factory fiberglass swim platform ???
Mine is faded and it turns your a$$ and feet black when you touch it. I want to replace the covering with something else but don't have any ideas right now.
Replacing it with a tubular IS NOT a option as I am selling this boat next year.
Any ideas ????
Thanks,
Dave
Smitty is offline
Old 06-11-2003 | 03:18 PM
Steel Outlawed's Avatar
Here's a link, look about middle way down.
http://www.offshoreonly.com/forums/s...threadid=42868
Steel Outlawed is offline
Old 06-11-2003 | 03:33 PM
garshev's Avatar
Lightbulb
A friend of mine removed it from his 38 special and found out how slippery it was. I would remove it and either roll on some tacky gel or just use some anti slip tape that they use on the tubular swim plats.
garshev is offline
Old 06-11-2003 | 04:07 PM
Smitty's Avatar
Steelware--
Thanks I sent a PM to Johno
Smitty is offline
Old 06-11-2003 | 10:30 PM
Default Swim Platform
Bigwavz.
I sent you A pm, Did you get it?
Heat gun, Goof-off & plastic putty knife/scraper to remove.
Hydroturf for the matt( just about any color you want)
Use Luane wood to make a template & cut the Hydro-turf to size with Razor knife. Piece of cake!
John
Johno is offline
Old 06-12-2003 | 07:03 AM
Smitty's Avatar
Thanks Johno !!!!
I will look up Hydro turf today. What did you use to reglue the stuff down ??
Thanks,
Dave
Smitty is offline
Old 06-12-2003 | 04:43 PM
Default Contact adhesive
Bigwavz,
Hydro-turf will send the glue & brushes, everything needed to glue it down.
Johno is offline
thedonz
Swap Shop
5
11-09-2008 06:36 PM
torian
Wanted
0
01-16-2008 10:23 AM
dlrider
Baja
8
08-28-2007 05:54 PM
phaze
Baja
2
04-27-2007 07:32 AM
barron
Cigarette
3
01-02-2005 10:56 PM
